Quick Wheel Question.
Old Oct 27, 2007 | 12:48 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
I have a chance to get Z06 style wheels for a killer price.
They're 17x8's and the offset is 5-4.75.
Will these fit without any spacers, or rubbing at all? Thanks!
Old Oct 27, 2007 | 06:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Quick Wheel Question.
5 by 4.75 is the bolt spacing not the offset or backspacing. usually the corvette wheels require spacers
Old Oct 27, 2007 | 07:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A corvette 8" rim will probably have around 6" of backspacing. This will push the wheel too far under the fenders on a third gen without some sort of spacer.
Old Oct 28, 2007 | 03:33 AM
Engine: 3.1
They're not exact Z06 wheels, just styled that way. My bad of the bolt spacing, the offset is 5. Here's a picture of the sticker on the box:
Will those fit under a third-gen?
Old Oct 28, 2007 | 11:35 AM
AlkyIROC's Avatar
Car: 87 IROC L98
I would say no based on what I see.
Backspace is the distance from the back of the rim to the mounting surface. Offset is the distance the mounting surface is away from the center of the rim.
That box says an offset of 5. You can't have 5" of offset on an 8" rim. If the offset is 0.5" then the rim has a backspace of 4.5" and should fit.
Rear rims are more concerned about backspacing for fit. Front rims especially on front wheel drive cars need to know offset more because when they turn, it will determine a lot of other factors.
Jorlain
Aug 24, 2022 05:11 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
downsouthboy
Aug 29, 2015 11:29 AM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
