jegster torque arm
Old Nov 10, 2007 | 07:50 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
jegster torque arm
those of you that have a jegster torque arm. how do you like them and would you buy them again? looking at buying the adjustable.
Old Nov 10, 2007 | 08:14 PM
texan_rebel's Avatar
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
Re: jegster torque arm
i would say just spend a little extra and get the sphon or edlebrock arm
Old Nov 10, 2007 | 08:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well you can forget about the edelbrock arm, crap
some people here use the jegster arm and love it, its shorter so it acts faster and frees up some room for exhaust clearance over the spohn/UMI arms
the issue that has come up is the use of the "slidelink", it needs to be lubed regularly or it can seize up.
Old Nov 11, 2007 | 07:08 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
i looked into that because i have true dual 2.5's running all the way out the back. and i didnt want to relocate it. is anyone running it will 60's in the 1.6's or better.
Old Nov 11, 2007 | 01:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes the jegster is on my car and several of my buddies cars and we all like it. A 1.6 60' isn't a very fast car either, so it'll be more than enough for whatever you want to do.
Old Nov 11, 2007 | 02:01 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
i cut a 1.66 on an 11.7 time im planning on getting the 60's down in the 1.5's. just wondering if it was capable.
Old Nov 11, 2007 | 02:27 PM
xpndbl3's Avatar
Car: 1984 Z28
like i already stated it will be fine for a 1.5 as well, I've seen them in the bottom 1.4s with no issues.
Old Nov 11, 2007 | 02:41 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i got the arm, but i havent installed it yet, i think it will be more than fine, its tubular and takes the strain of the rear of the trans which is the main purpose, the fact that its shorter also makes it stronger than the long length ones. i got mine partly used and threw on a couple coats of POR15 black and it looks amazing.
get it!
im putting it in when my 500hp 383 is completed over the winter. hoping for high 11s as well, the arm should def help
Last edited by customblackbird; Nov 11, 2007 at 02:42 PM. Reason: Automerged Doublepost
Old Nov 11, 2007 | 05:53 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
thats the main reason im getting one because i have alread broke a tail shaft housing.
Old Nov 11, 2007 | 05:59 PM
Car: 87 TA clone
thats why it takes the mounting off the rear of the trans.
Old Nov 12, 2007 | 06:09 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
those of you that have it would you buy it again?
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
