Suspension help, rear springs
Old Nov 16, 2007 | 08:39 PM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
Did the 89 lo3 cars have insert blocks in the rear springs to raise them??? Cause I bought a car and the rear suspension is horrible and i think someone added them in. Should i take them out or leave them in?
Old Nov 16, 2007 | 10:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Suspension help, rear springs
Huh?
Got a picture?
No "insert" blocks..? But there is a spacer at the top of the rear spring, about a 1" tall rubber ring.
Old Nov 16, 2007 | 11:50 PM
Car: 89 Camaro RS
Originally Posted by Sonix
Huh?
Got a picture?
yeah like someone took the spring off where it was not compressed, and put a block insert to raise it, looks like something you would see done to a truck or jeep, and then compressed and put back on... just under the middle of the spring
Old Nov 17, 2007 | 12:25 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
The only thing that is stock is a rubber ring that sits between the TOP of the spring and the body of the car. It raises the car about an inch and is stock for it to be there. Any block or anything on the bottom of the spring is not stock.
Got a picture?
Old Nov 17, 2007 | 10:28 AM
Car: 89 Camaro RS
yeah here is a pair like it on ebay. http://cgi.ebay.com/ebaymotors/MR-GA...QQcmdZViewItem
you put that between 2 rows of the spring, and the coil sits in one of the grooves and when you compress it and put the spring back on the car sits higher
hm i wonder if i need to take that out, or if they had it there for a reason
Old Nov 17, 2007 | 11:22 AM
Sonix's Avatar
Car: 1982 Trans-Am
Rear springs are very easy to remove, not like fronts.
You can remove them, but i'd guess the rear springs got quite soft, and he was bottoming out, so he put them in, rather than putting in new $80 springs. Or does the car have big rear tires or something?
Can't hurt to try to remove them. Jack up the rear of the car by the pumpkin, as high as you can, put jackstands under the axle tubes, then put something below your jack and jack up the pumpkin again, higher. You've gotta get it REALLY high. Then finally put the jackstands under the rear frame rails. Remove the jack and the rear end will sag.
Jack up the pumpkin a few inches, then remove the 3/8" nuts on the rear sway bar ends, and the bottom nuts holding the shocks onto the rear end. Now start lowering the jack, the rear end should come a lot lower than before. Hopefully you have the car high enough, that you can lower the jack almost to the ground, then you'll notice the rear springs just want to fall out. Now you can remove the blocks, and replace the springs with new ones if you want.
Any parts store will have MOOG CC635's for about $60 or so.
Old Nov 17, 2007 | 02:35 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I would get some Moogs and just swap out the springs. I don't see those blocks in the springs being beneficial to handling, lol. Might want to go ahead and do the fronts as well. It's not really that big a deal, especially comapared to the coil-over set-up of Hondas/Integras I've worked on.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
