looking for upgrade on the suspention.
Old Nov 29, 2007 | 01:53 AM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
i have 88 Z28 with bone stock suspention on it. Im looking tto upgrade it and looking for suggestions to what i should go with. Mostly drag racing is what i would perfer. I want to upgrade the read first so what should i start with???
Old Nov 29, 2007 | 05:00 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: looking for upgrade on the suspention.
Sphon sells everything you need.
Rear lower contrl arms
Panhard bar
Torqu arm mounted to a cross member
If you wanna go all the way get the K member and front lower control arms.
700$ or so for the first 3 and add 700-900$ for the last parts.
Old Nov 29, 2007 | 08:46 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
How much hp you're making will determine how much you should buy. A good start is subframe connectors, lower control arms, and panhard. First thing you should get is subframe connectors, HUUUGE help. V6 springs will also help with weight transfer. With a 305 I dont think you will benefit much from anything else.
Old Nov 29, 2007 | 02:42 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Damn, i have subframes, i need everything else so i guess i listed what i have been thinking about.
Old Nov 29, 2007 | 11:34 PM
Engine: TPI 350
Transmission: TH350
ok sweet thanx for the help. The stock suspension hopps at the track from the line. What do you think would cause that.
I make about 200 from i think 170. I just have the whole msd ignition setup. and edelbrock performer. After that its all stock.
Last edited by travishenry; Nov 29, 2007 at 11:36 PM. Reason: Automerged Doublepost
Old Nov 30, 2007 | 12:28 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is your(our) junky stock torque arm flexing, the aftermarket pieces cure that, lower control arms for the rear help too.
Old Nov 30, 2007 | 06:59 PM
Engine: TPI 350
Transmission: TH350
thanx for the help. I need to get right on that cuz i try hella hard to launch as good as i can but still the rear hops and it feels like an earthquaik in the car. but tanx for the help.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
