panhard bars and lower control arms. new ones needed?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
im going through my suspension and i was wondering if its nessessary to replace my panhard bar and lower control arms????
if so... why?
if so... why?
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
Re: panhard bars and lower control arms. new ones needed?
If you just glide with your car not lowering it i would say not needed.
If you lower your car i would say adjustable panhard bar is needed maybe also brackets to realocate your lower control arms to avoid risks of wheelhop.
If you go to the track i would get both parts with polybushings definitely gets more stability to the rear,you could also box the original parts with a good result as i understand but whats best i dont know.
From my own experience after installing Lakewoods adjustable panhard bar and lower control arms with polybushings rearend got very solid and wheelhop disappeared.
regards Mats
regards Mats
Do you need them, well no. But did you say you were upgrading? Look at the stock ones and the "U" shaped stamped parts and then check out the Spohn Tube type Rear LCA's & Panhard bar. Which ones do you think are better?
I have both + SFC's and they made a hell of improvement.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You could replace just the bushings on your factory parts.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
If you are looking to upgrade, you can build your own. It's what I did.
Sorry for the crappy pictures.
Either way, don't run poly in the LCAs if you are looking for handling or a quiet ride. It binds under cornering loads and releases the tension (in interesting ways) when you exit and it squeaks like mad when even if you grease them regularly.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
My boxed stock LCA's using ES poly bushings never squeaked once. I did however notice a few times, what I would describe as the "bind". Kinda weird feeling.
I made the exact same LCA's as 91_5.7 there, except the tubes are fully hex.
UMI makes some of the BEST products for our car. here is a great place to order from and they have free shipping
http://www.lmperformance.com/18392/7.html
It's cheap, and AHELLUVALOT easier than trying to change out the bushinge in the stock ones.
So if the bushings are bad (which they most likely are), it's not a bad idea.
On my car I have a replacement stocker PHB that's been boxed in, and Lakewood LCAs with poly bushings. Seems to work great.
Car: 1991 RS Camaro
Your's didn't squeak? Mine did it just about all the time, especially when it was winter. What brand were yours, maybe a better poly?
Car: 1982 Trans-Am
Mine are ES (Energy Suspension) all around.
I don't drive my car in winter at all - too dangerous.
Axle/Gears: no idea
anyone know any sites or anyone selling a complete kit for around 100 bucks give or take?
i know theres no way but for 200 i can put taht money elsewhere at this point but if the price is right ill do it sure no problem
Car: 1982 Trans-Am
kit...? For.... Including?
Axle/Gears: no idea
panhard bar and lower control arms for less than 150
Car: 1991 RS Camaro
Replace stock rubber!!! haha
Driving in winter is only dangerous if the driver can't drive or if there's ice on the roads.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
