Steering gear adjustment nut broke??
Old Dec 3, 2007 | 09:53 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Now what...
I was trying to tighten some slack up in my steering and was loosening the jam nut and the nut broke the shank off even with the gear cover. I am no longer worried about slop in the steering. Just want to make sure without that jam nut I will be ok. I.E. it won;t come apart while turning on some back road?
The adjustment screw will not move either. I tried removing the gear cover and it would not unscrew.
Steering works fine, at least as much as it did.
Old Dec 4, 2007 | 09:42 PM
IROCmenace's Avatar
Car: 1988 IROC
Re: Steering gear adjustment nut broke??
Ok, so I have now answered my own question. Came out to the garage to work more on El Diablo (the car) and I find a nice puddle of power steering fluid under the gear box. Evidently that nut keeps fluid from coming out as well. So I will be changing the steering gear this weekend. Did discover my problem though. I could finally see that the center link bushings were shot.
So if anyone else sees this on a search because they broke their adjustment nut/shaft, go ahead and replace the unit.
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Sep 29, 2015 01:50 PM
86IROC112
Aug 21, 2015 07:20 PM
redmaroz
Aug 16, 2015 11:40 PM
dhonda200
Aug 11, 2015 11:50 PM
