Front coil over problems
Old Dec 5, 2007 | 11:56 AM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I know that this has been covered in the past, but I realy want to know guys who are running a front coil over system what do you think?
I just installed a spohn pro drag front coil over system on my street strip 87 firebird (street to the track and road test runs) and I do not want any problems.
People that do not even have this set up are salways saying the towers will not support the weight. I want to here it from someone who has this suspension.
I am also thinking of welding extensions to the spohn underside 1/4" support plates to also include the holes for my strut tower brace, what do you guys think, is it needed.
Old Dec 5, 2007 | 06:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Front coil over problems
ive got the pro-tour setup, ive got a 3pt solid mount strut tower brace with bolts going through the reinforcement plate, it seems to be plenty strong, though ive not had the setup long.
Old Dec 5, 2007 | 07:42 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I have PA Racing and no problems.
Old Dec 5, 2007 | 07:52 PM
Car: 1987 firebird
Transmission: 4l60e
//<86TA>\\ how long have you been running this set up? Do you also run on the street at times?
Old Dec 5, 2007 | 07:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its the "street" setup, the car is primarily a street car, unfortunately ive only drive then car about 20 minutes since i installed the kit, now its snowing
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
TA8487
Aug 11, 2015 09:02 PM
