Thinking of a Cage
Old Dec 1, 2007 | 08:24 PM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Thinking of a Cage
Im building a nasty pump gas SBC..and its almost ready to be in the car..Im going with a TH400 and It has a Moser 9in already..the car is an 1987 GTA..Its a street car that I will/ and do drive. Should I put a cage in it..or just a roll bar? The inside is all great shape..I redid a lot of it..Im looking to run low low low 11s on motor..and idk were at with spray..but is there anything I need to know about puting a cage in or what? Whats the best?
Old Dec 1, 2007 | 09:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Thinking of a Cage
A 6 point roll bar is fine down to 10.0 as long as the floor and firewall are not modified. You can install swing out door bars to make getting in and out a lot easier for street use.
A 6 point bar adds about 70 pounds to the car. A full cage depends on how many extra bars go in. My cage has a sill bar, X bars in the doors and a knee bar.
As to putting them in, the cost of a roll bar/cage kit is cheap. I bought my basic kit from Jegs which came with a couple of prebent tubes and a bunch of straight tubes with notches cut on one end. The cost of having one installed is expensive. Getting a chassis shop to put one in, you can estimate $100/$150 per point. Interior needs to be removed, plates need to be welded to the floor for the tubes to attach to, tubes need to be cut to length and maybe notched. You need to either MIG or TIG all the welds.
Installing a roll bar or cage means nobody will be able to easily use the back seat any more.
Old Dec 1, 2007 | 10:01 PM
87_GTA_5.7's Avatar
Yeah ..the back seat is to small anyway..Im yound and dont plan on kids so..lol but I think Im ganna end up geting a cage from Jegs or summit..and put it in..Im not looking ot make it a full blown race car ya know but just to keep it safe and legal at the track..is that ur black Camaro?..if so..nice times..and looks awsome!
Old Dec 1, 2007 | 11:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Yes that's my car. I bought it as a basic street car back in 1999 with a carbed 383 stroker in it and I never drove it on the street once. It stripped it down and made it into a race car from the day I owned it. In 1999 it ran 15's. It now runs mid to high 9's and can never be made street legal again.
Old Dec 4, 2007 | 03:32 PM
Shagwell's Avatar
Car: projects.......
there's a lot of info on here about roll bars/cages if you do a search. - NHRA/IHRA tracks require a minimum of a 6-point for all cars that run 11.99 or faster.
a roll bar makes the back seat beyond useless. In the event of an accident it can be the cause of death for some one riding in the back.
Old Dec 4, 2007 | 09:53 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Axle/Gears: Ford 9" with 3.89
I thought that a 6 point roll bar is needed when you are 11.49 or faster?
Other than Competition, who makes roll bars for f-bodies?
Old Dec 4, 2007 | 10:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Actually it's a minimum of a 5 point bar at 11.49 but everyone puts the passenger door bar in for the 6 point. NHRA only lowered the time from 11.99 to 11.49 to match IHRA rules within the last couple of years.
Old Dec 6, 2007 | 09:24 AM
87_GTA_5.7's Avatar
Well Im sure it will run around 11.50s..Im runing 12.8s-9s with a 75 shot on a stock TPI 350...It dynoed at 489 and then a 200 shot..but I dont want people to walk up to it and see a cage..then they know its fast..but do is a roll bar is ok? will that be enough? Im not wanting to tear up my beautiful interior!!
Old Dec 6, 2007 | 11:23 AM
Shagwell's Avatar
roll bar and subframe connectors will do you fine. - I've got a buddy running a drag radial mustang coupe, runs mid 5's in the 1/8, mid 8's in the 1/4. He's only got an 8-point. Got thrown at of our closest 1/4 mile a few weeks back though.... - They let us come back, but only if he shuts down after 1/8.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Jan 29, 2017 07:00 PM
overdriv
Aug 20, 2015 03:52 PM
z28addict8490
Aug 7, 2015 08:48 PM
