Need a Harness Bar!
Old Dec 11, 2007 | 11:51 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Need a Harness Bar!
I cant find anyone that makes a harness bar for our thirdgens. I dont want a roll cage, just something I can put in for when I autocross so I can get a 4pt harness. Do you know of anyone that makes it, or have made your own and don't mind sharing info on it?
Old Dec 12, 2007 | 02:03 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Need a Harness Bar!
no one makes a harness bar, theres no where to bolt it to as the seatbelts are practically on the roof. Allthough its not the safest in a rollover, you could always mount the harnesses to the floor. Otherwise a 4pt rollbar is about your only option. You could make it with quick release pins and remove it when you're not killin cones.
Old Dec 12, 2007 | 03:35 PM
Car: 1987 IROC-Z
Transmission: TH350
Is there a way to mount it where the rear shoulder strap would be if my car had a rear shoulder strap on the seat belt? I've seen people with the rear shoulder belt in their cars so I know it can be done. I mean if that part of teh car is safe enough for the actual seat belt to mount to, why wouldn't it be safe enough for a harness bar?
Ill try and find a pic of the area I'm talking about.
Old Dec 12, 2007 | 03:43 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
2 choices:
use your factory seat belt and skip the harness
put in at a minimum a 4 point bar with hoop.
Old Dec 12, 2007 | 03:52 PM
Car: 1987 IROC-Z
Transmission: TH350
This pic isn't really what I was looking for but that's the mount I was thinking of attaching the bar to.
Old Dec 12, 2007 | 03:58 PM
xpndbl3's Avatar
Car: 1984 Z28
those bolts and brackets were never designed to have a bar put across them and the loading that would occur in an accident with the extra leverage from a bar put on them. think of pulling on a 1/4" ratchet then pulling with a much longer 1/2" ratchet
Old Dec 12, 2007 | 04:08 PM
Car: 1987 IROC-Z
Transmission: TH350
I only plan on putting it in for autocross and then taking it out. The fastest I can ussually get going is probably 40 mph and then I'm on the brakes right away. I just need it strong enough to hold me in the seat for when I lean forward when I'm on the brakes and such. If that little bolt can hold the shoulder retractor why wouldnt it hold a bar the front shoulder straps would mount to?
Here is a better picture of what I want to do.
bar, seatbelt
J-money
Jan 4, 2019 09:45 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
Billy Decker
Sep 4, 2015 03:46 PM
