LCA hilarity
Old Dec 13, 2007 | 10:41 AM
Dents's Avatar
Car: 91 Camaro Z28
Engine: L98 5.7L
Axle/Gears: Ford 9" with 4.30s
LCA hilarity
So I was driving around town and I noticed that my car felt weird. It was also kind of making a noise, which sounded like something was rubbing somewhere. I figured my brake pads were wearing out and made a mental note to check it out when I got home. But, before that, I had errands to do. So after I did my stuff, I get in the car and start backing out of a parking space. All of a sudden the car feels like the rear end disappeared and it's just sitting on the rear tires. I let go of the clutch and it rolls forward just fine. WTF?!
That happened:
http://fitscc.fit.edu/album_pic.php?pic_id=935
Old Dec 13, 2007 | 12:14 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: LCA hilarity
Time to send a letter or two I think!
Old Dec 13, 2007 | 03:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: LCA hilarity
Doesn't look like a very good design.
Old Dec 13, 2007 | 03:25 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: LCA hilarity
no torque arm i take it looking at that design, guessing the metal finally fatigued at that joint point and broke.
Old Dec 13, 2007 | 03:33 PM
Shagwell's Avatar
Car: projects.......
Re: LCA hilarity
very similiar to the lakewood traction action bars / g-force ladderbar/lca's. - all in all, it's a bad design, and now you know the results.
Old Dec 13, 2007 | 04:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LCA hilarity
maybe someone hates you and saw-zalled it.
Old Dec 13, 2007 | 04:24 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Re: LCA hilarity
That break is so clean, it LOOKS sawzalled! Good luck!
Old Dec 13, 2007 | 04:32 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: LCA hilarity
Yep. Looks like it was sawzalled to me too.
Old Dec 13, 2007 | 04:51 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: LCA hilarity
What type of bushing is that on the chassis side? It looks like there is not a spherical bearing. With no free moving bearing, whenever you turn with a setup like that, you bind up, and that probably overworked the metal in a twisting force. I broke a Spohn LCA in a simlare fashion (broke where the bushing went into the tube).
This kids, is why I always tell people, they need to run a spherical bearing on the LCA's to avoid bind!
Old Dec 13, 2007 | 06:27 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: LCA hilarity
Just so there is no doubt, if you look at that flake of paint coming off of the edge of the cut you can tell it clearly wasn't cut. It seems like that was a bad spot on the LCA to be putting a lot of pressure on, although I don't know what kind of forces get put on that (apparently the manufacturer didn't either).
Old Dec 14, 2007 | 12:28 AM
Dents's Avatar
Car: 91 Camaro Z28
Engine: L98 5.7L
Re: LCA hilarity
Yea the other LCA is in an earlier stage of cracking, so it was definitely shitty design and not sabotage. The 9" did not come with a torque arm bracket, but did come with these LCAs. I wanted to enjoy the 4.30s, so I threw it on without a torque arm, just temporarily. I guess it's back to the 10 bolt for a while
Incidentally, does anyone know where I can buy a torque arm bracket for the 9"? I know moser makes them, but I can't find them listed for sale *anywhere*
Old Dec 14, 2007 | 04:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: LCA hilarity
does your 9" have the mounting tubes for the bracket? if so just give moser a call and ask if you could buy one
Old Dec 14, 2007 | 05:59 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: LCA hilarity
currie sells just the bracket and tubes IIRC, give them a call and ask. quit wasting time looking online when a 30 second phone call to moser or currie would answer it. Neither of their websites are very helpful.
Old Dec 14, 2007 | 06:23 PM
gary sanders's Avatar
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
Re: LCA hilarity
Looks like that was like that for some time,looking at the rust on the break,but at the very bottom of the break,you can see where it was barley holding it all togeteher. I bet you was like WTF HAPPENED?
Old Dec 14, 2007 | 09:30 PM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
Re: LCA hilarity
damn I think I'll use a LCA with a bearing when I change out mine now.
Jorlain
Oct 8, 2015 01:57 AM
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
