Will these fit my 91 RS???
Old Jan 1, 2008 | 08:53 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
Here's the info....
5x114.3/ 120mm Bolt Pattern with 38mm offset
Thanks for any info needed like spacers?
Old Jan 1, 2008 | 09:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Will these fit my 91 RS???
5x4.75" will fit depending on width of rim will tell you if the backspacing will clear.
Old Jan 1, 2008 | 09:23 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
Holy hell...... sup xpndbl3??? it's Rob from CTR.... yeah, found these on ebay, so they should fit then?
They are 18x8
Old Jan 1, 2008 | 10:07 PM
xpndbl3's Avatar
Car: 1984 Z28
I'm not sure what 4.75 is in mm, but I'd double check before buying something that won't fit. Rims with spacers look stupid on these cars because it shows off the overly small brakes even more.
Old Jan 1, 2008 | 11:11 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
understood, but the Baer Brakes I have look so good they need shown off, LOL!!!
Thanks for the info, I'm just gonna pass and wait to get some made for the car like suggested.
Old Jan 2, 2008 | 01:40 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
4.75 = 120.6mm
I have read a post from someone who works for a wheel shop that 120mm will fit.
Just need to be cautious about offset and spacers. Maybe consider a 4th gen rear?
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
