will it fit?
Old Jan 4, 2008 | 12:27 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
will it fit?
im thinking of buying four cragar ss series 61 wheels, for the front im thinking 15x8 and for the rear 15x10, would i have problems running those in the rear? i just have no clue how big of a tire i can run on a stock body, for tires out back i would i like something like 325/50r15, would they fit? if they wouldnt fit i might go with 8 inch wheels all around, if so would 8 in wheels with 275/60r15 fit? would these fit in the front also? thanks in advance guys!
Old Jan 4, 2008 | 12:54 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: will it fit?
325 on a 10 inch wheel is a little too big but is doable, you will probably have a real "bubbly" sidewall. i run 315 on my 11's and its perfect. i have seen guys run the 335's with no fitmit issues. you will need a 0mm offset though.
Old Jan 4, 2008 | 01:10 PM
Car: 85 camaro
Axle/Gears: 342
Re: will it fit?
im looking at nitto 555r's, and im summit, the 325/50r15 s suggested rim size is 9 to 11.5 so i figured id go right in the middle with a 10, plus they dont have the 61 series in a 15x11, so these will fit with no problems? how far will they stick out of the wheel well? also on the front, will the 15x8s fit with 275/50r15's?
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
