Riding really hard
Old Jan 6, 2008 | 04:45 PM
blakbird89's Avatar
Car: "Nina" 1988 Trans Am GTA
Engine: TPI 305 V8
Riding really hard
My car seems to be riding really rough compared to newer cars. I put new rear shocks on last year and I haven't changed the front yet but it still rides so hard on even reasonably normal roads. Is this normal for all thirdgens or is there something I can do about it? My friend said it might help if I put in a smaller driveshaft but I don't think it would handle the same. Any ideas?
Old Jan 6, 2008 | 05:23 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Riding really hard
welcome to 3rd. gens. . none ride real well unless on a smooth road , fatter tires might help , as would new seat foam . they will never ride like a 4dr. sedan . ( i for one would not want mine to ) just be more aware of dips , potholes , etc. , and have fun driveing .
Old Jan 7, 2008 | 04:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well if it rides hard thenit means the suspension is not compressing very much
either not soft enough springs, or the struts or shocks are not compressing easily, are too resistive to compressing
the springs are there to keep the car from compressing and uncompressing more than about a jounce and a half
the springs are to make the ride
some are stiffer than others
if shocks or struts are too restive to compression then they can make the car bounce over bumps and make for a hard ride
its kinda hard to comprehend, think about
same concept as in a truck, the more leaves in the packs then the harder the ride and less compression there will be over bumps and so forth
the shocks have nothing to do with it
the old 1 ton trucks had so many leaves in the packs commonly that shocks were never even installed and were instead optionally available
had no need for them
i have had many old 1 ton dually trucks that never got any rear shocks the last one was a 67 C-30 r05 dually conversion package
the stiffer parts are on the susension then the harder it is going to ride over bumps and so forth
need to soften it up
good luck
Old Jan 8, 2008 | 03:38 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
I just pulled a set of gabriel red gas charged shocks off the rear and replaced them with KYBs , the difference is unreal , I actually think my car handles high speed off-ramps better now and my cd player doesn't skip on every crack in the road .
Old Jan 8, 2008 | 05:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Get a new friend. Under normal circumstances, the drive shaft would have nothing to do with ride quality.
JamesC
Old Jan 8, 2008 | 01:16 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
JamesC
LMAO!! Also, a smaller one wouldn't help anything either
What kind of shocks did you put on the back of it? Also, when you say rough, do you mean like, you hit a bump and a tooth falls out or more of a vibration?
Breazlan
Sep 25, 2015 11:20 AM
Linson
Sep 21, 2015 01:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
Randomtask2
Sep 7, 2015 05:06 PM
