SFC's with a few restrictions
Old Jan 19, 2008 | 07:56 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Following is a list of restrictions that the SCCA has created for the street prepared autocross class with reguard to SFC's. I'm looking for some recommendations that will fit within these rules. My initial thought is that I will likely need to make my own. I have never paid much attention to SFC's since up until now no SFC's were allowed in this class so I'm not too sure what's out there.
E Longitudinal (fore-aft) subframe connectors (“SFCs”) are permitted with the following restrictions:
1. They must only connect previously unconnected boxed frame rails on unibody vehicles.
2. Each SFC must attach at no more than three points on the unibody (e.g. front, rear, and one point in between
such as a seat mount brace or rocker box brace).
3. SFCs must be bolted or welded, but welding must be to the OE subframe stampings, not to the floorpan in
between.
4. No cutting of OE subframes or floorpan stampings is permitted. Drilling is permitted for mounting bolts only.
5. No cross-car/lateral/triangulated connections directly between the driver’s side and passenger’s side SFCs are
permitted. Connections to OE components such as tunnel braces or closure panels via bolts are allowed and count
as the third point of attachment. No alteration to the OE components is permitted.
6. SFCs may not be used to attach other components (including but not limited to torque arm front mounts or driveshaft
loops) and may serve no other purpose.”
Old Jan 19, 2008 | 08:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: SFC's with a few restrictions
from what i see, just about every subframe connector on the market will work, only issue could be spohns because they are usually welded to the pinch rail and that is not allowed
Old Jan 19, 2008 | 08:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
To me it looks like only something like the Alstons would be legal.
Old Jan 19, 2008 | 08:40 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Wow thats strict. I guess my Spohn's cant make it. heh
Old Jan 20, 2008 | 07:44 AM
Souseless's Avatar
Car: 89 WS6
It is restrictive but it is better than no SFC's which was the case previously. I looked at the spohn's and if you skip the pinch seam welds I'm still not sure if the front tie in point is ok. The description is simply "behind the front wheel well" and I could not tell from the photos. Also not sure how effective they would be without the pinch seam welds. I will check Alstons next. I'm thinking the old Southside Machining design would fit.
Old Jan 20, 2008 | 10:06 AM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Suck they don't allow a cross brace ie (Torque arm,drive shaft loop) My SSM are fine if I didn't seam weld them to the whole floor pan. And I will be running the BMR Ex-treme Torque Arm.
Are Roll-Cages allowed?
Old Jan 20, 2008 | 11:45 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
UMI SFC's only have 3 connection points to the car. One at the front subframe, one at the transmission tunnel and one at the lower control arm. By the description in item #5, this seems legal even though all three spots are welded. But items #2 & #3 make the fact that they are welded seem OK
3. SFCs must be bolted or welded, but welding must be to the OE subframe stampings, not to the floorpan in between.
5. Connections to OE components such as tunnel braces or closure panels via bolts are allowed and count as the third point of attachment. No alteration to the OE components is permitted.
Also seems that a bolt used on the tunnel brace would make these OK...
Old Jan 21, 2008 | 11:00 PM
Souseless's Avatar
Car: 89 WS6
It looks like the UMI fits the need. It looks like it is a bit on the heavy side though. So far that is the best option I've seen. The way I read it the third point only needs to be bolted if it attaches to bolted component. The UMI attaches the third point to the sub frame so it should be good. Any other options
Old Jan 21, 2008 | 11:18 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
I just put the UMI's on my car. The connectors themselves are great, and strong. Just make sure you have a really good welder put them on. I tried to save money by having a friend put them on, and now I screwed myself over because I have these heavy red things permanently attached to my car, but they dont do a thing for it except make the t-tops squeak more, and some funny other noises.
[link]https://www.thirdgen.org/forums/aftermarket-product-review/456257-umi-subframe-connectors.html[/link]
Old Jan 23, 2008 | 02:07 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'm glad to hear this since I will be swapping out a lot of my suspension for the 08 autocross season.
Wouldn't the Spohn sfc work as long as you don't pinch weld to the floor? I've heard/seen that they tuck under the car better than anything else which is good for me because I like the stock look.
Old Jan 24, 2008 | 08:19 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Hmm... this is good news. It looks like I'll have the guy installing my Spohn SFCs to not do the seam welding. Seems like they would be legal from what I can tell. Probably pointless though, cause my car is probably an ESP car without the SFCs. I just need to get another car to auto-x with and just finish this one as fun street machine.
Old Jan 27, 2008 | 02:53 PM
Souseless's Avatar
Car: 89 WS6
Yes I do think the spohns work with out stitch welding to the pinch frame. What material are the UMI's made of?
Old Jan 28, 2008 | 02:37 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
This is off there site....
Features:
- Built using 2.000” x 1.250” x 0.120” Mild Steel Rectangular Tubing
- CNC Machined 0.188” Thick Mild Steel Mounting Points
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
cheesehomer
Dec 31, 2015 08:48 AM
Zell1luk
Sep 29, 2015 10:36 AM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
