3rd gen spindle-what material?
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ive seen this tossed around several threads.
are the stock spindles cast STEEL or cast IRON.
im no metal expert.
im no metal expert.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 3rd gen spindle-what material?
For the most part, they are cast iron. However, the part that pokes out, and what the bearings ride on, is a separate, pressed in, piece. It could very well be, and likely is, Steel.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I cut my caliper mounts off to install an aftermarket brake system, it looked like steel to me. Cast iron can be easily broken from a sharp hit. Drop a cast crankshaft of camshaft on the floor and it can break since they are cast iron. Hit a spindle very hard with a hammer and it will bend before it breaks.
You can always do a spark test
http://www.tpub.com/steelworker1/6.htm
Nodular Iron is used for automotive castings. A stonger material then normal gray iron castings.
