rack and pinion on stock k member
Old Jan 31, 2008 | 11:20 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
i have asked it before and had been told a "no" but now i have seen a picture of it and wondered what it takes to put a rack in my 91. i do not want to go to a tubular k member b/c that is a pain in the butt and i can not have my car out of comission that long. anyone do it? maybe a step by step? and i want a power rack setup ( i know i'm picky)
Old Feb 1, 2008 | 02:43 PM
Shagwell's Avatar
Car: projects.......
Re: rack and pinion on stock k member
https://www.thirdgen.org/forums/susp...ghlight=bird+t
there's a considerable amount of info about rack swaps using the search key. - yes, it's been done using the stock k-member, if you have decent fabrications skills, it's not very dificult. The thing is, it's only been done successfully for drag race only use, as most rack & pinions don't have enough travel to accomidate a full turning radius. - Most will approximately double your turning radius.
All things said, unless you're down to shedding those last few pounds(obviously not when utilizing a stock k-member) and are going to a manual rack, there are no gains to be had. There's just as many wear items to replace. Most racks will develope on-center wear(slack at straight forward) When rebuilt, this can be fixed in a steering box, but it is not something they replace in racks, thus it is often aparent in part-store racks, and most always in jy take-outs.
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
Nov 16, 2015 01:13 PM
Linson
Aug 21, 2015 02:12 PM
overdriv
Aug 20, 2015 03:52 PM
PestilenceIV
Aug 20, 2015 02:33 AM
