how hard is it to remove a k member
Old Feb 8, 2008 | 12:56 PM
monsooni's Avatar
Car: 83 camaro
Engine: 355 sbc 525hp
Transmission: 350 turbo built
Axle/Gears: 4.56
ok, I got the A arms dropped down and the springs out of it, and i am still alive lol. Anyways what do you guys think about just dropping the whole k member while i am this far and clean everything up and repaint it. Or get a spohn tubular K member for it . only thing i am worried about is it being ok to drive on the street thx all
Old Feb 8, 2008 | 06:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how hard is it to remove a k member
its just bolted on. but the engine is sitting on it, you will need to support the engine first. there is also a brake line attached to it you dont want to forget about
Old Feb 8, 2008 | 06:30 PM
monsooni's Avatar
Car: 83 camaro
Axle/Gears: 4.56
I got it the engine was already out, kinda scary that there is only 6 bolts holding my front end on .
Old Feb 9, 2008 | 07:42 AM
Yup, 6 bolts is all that holds the K-member to the rest of the car....
There's a bunch of other minor floobie dust, stuff like brake lines, little reinforcing brackets, and such as that; but basically, from where you are right now, it's ... 6 bolts.
It'd be a good idea to pop the CAs off the K-member and put new bushings and ball joints in them, since you're already there; and swap the motor mounts too.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
lt1z350
Aug 28, 2015 05:57 AM
Linson
Aug 21, 2015 02:12 PM
3rdgenparts
Aug 8, 2015 07:09 PM
