subframe connectors
Old Feb 13, 2008 | 07:57 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
subframe connectors
I have a set of subframe connectors from a '98 T/A I use to own, they never seemed to make it on the car for some reason. My question is can I use them on my '87 T/A. Ive heard the chassis between the 3rd and 4th gens. is the same, is this true?
Old Feb 13, 2008 | 08:18 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: subframe connectors
Not quite the same.
You might be able to modify them to fit though. I believe the front subframes are different.
I think on the 4th gens, the car has threaded holes already in the subframes. The connectors make use of these to hold them in position for welding. Also, I think the 4th gen front subframes are a little different shape.
Somebody else will probably chime in and tell you a definate answer.
Old Feb 13, 2008 | 08:31 PM
That's a bummer.
Old Feb 15, 2008 | 09:00 AM
Shagwell's Avatar
Car: projects.......
The front "subframe" is very different and the modifications required to fit them would probably out weight fabbing a set or selling and buying the right set.
Old Feb 15, 2008 | 09:16 AM
Engine: LO3
Selling and buying the right set is probably the best idea. That way, there is no chance of ruining a good set of 4th gen SFC's because then they would just be scrap metal.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
