horrible traction
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
horrible traction
I have lowered my car around 3+ inches and since doing so I have horrible traction and bad,bad wheel hop. I only have about 1" between my bump stops and rearend. I can not raise my car due to the body kit. I can not leave a light without wheel spin under light throttle or wheel hop under heavy throttle.
Any thoughts how to improve this traction problem.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: horrible traction
control arm relocation brackets could help, not very expensive and worth a try. What is the rest of the suspension like? stock?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
LCARB's as mentioned are THE answer.
An adjustable torque arm might be another one to consider, and an adjustable panhard rod. That much lowering means you need to change everything.
Numbah-1
Sep 12, 2015 08:57 PM
Polo Z03
Sep 10, 2015 06:43 PM
