susp. bolt kit? such a thing exist?
Old Feb 17, 2008 | 05:36 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i am about to do almost a total rebuild on my suspension. i'm sure alot are either rusted or just junk.
instead of re-using the old bolts or just incase a few snap or whatever
i was wondering if theres a company or dealer that have a bolt kit for every part of your suspension?
thanks
i may not need them i dont know the condition of my 20 yr old bolts but just incase it would be nice to know
Old Feb 17, 2008 | 05:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: susp. bolt kit? such a thing exist?
no, no kits
Spohn sells most of the major ones, spindle bolts, i think a-arm bolts, control arm bolts, panhard bolts.
Old Feb 17, 2008 | 06:00 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
just go down to the hardware store, get some grade 8 bolts with lock washers and teflon nuts, you can never be to safe!
Old Feb 17, 2008 | 06:10 PM
Bobby_80s's Avatar
Axle/Gears: no idea
grade 8 bolts is that what they are called? sorry i know specific parts but bolts i'm not used to looking for since most kits come with the bolts. and i just use what came with the kit
Old Feb 17, 2008 | 06:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
they are NOT everyday, hardware store grade 8 bolts.
All the suspension bolts on the car are metric, grade 10.9, which in equivalent to grade 8. Grade 8 bolts, that are not metric sized will not fit properly in the holes, they will be either too big or too small, and some of the bolts, panhard for example, are "step bolts" which have a larger shank on the head side as opposed to the threaded portion. They are special to the application and to do things right you need the right bolts.
Old Feb 19, 2008 | 09:46 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Also, they aren't nylock nuts (no such thing as teflon ones). They are usually all metal lock nuts, aka "stover" nuts.
Bolt supply shops have most of these, and some (stepped bolts) you need to get from GM for $7/bolt
Old Feb 19, 2008 | 01:47 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Stepped bolts are the devil. That's all.
Oh, but on topic, if you get the devils out of the car and can stand a wait, I ordered all of my bolts from www.boltdepot.com. Be sure to get their bolt measuring tools. They'll tell you diameter, thread pitch, and length. Good stuff. It's how I ordered all of the bolts for my serpentine swap.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
hectre13
Aug 26, 2015 08:17 AM
Bob88GTA
Aug 18, 2015 03:31 PM
