new kyb shocks / struts .. and poly bushings .. gotta question?
Old Feb 24, 2008 | 07:27 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
i just finished putting in new kyb gr-2 struts / shocks .. and i got a complete set of energy suspension poly bushings ..
put on all the shock / struts .. the old ones were trash .. the piston would just fall into the base when i pulled it up ..
neways ..
put on new poly front sway bar mounts / end links ..
set the car back on the ground .. and now it sits up about 1" higher than it was ..
is this normal b/c the shocks were shot ..
also .. how long should i expect to spend putting the whole bushing set in when i get some time to do it ..
i put a set in my 89 mr2 and it was a HUGE pain in the a$$, i had to take a oxyacetylene torch to the old bushings then put it on a press
Reddeath210
Oct 6, 2015 08:20 AM
pgagnon42
Aug 24, 2015 06:50 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
