does anyone have a pic of underneath, i want to make my own subframe connectors
Old Feb 25, 2008 | 09:03 PM
tripingeorge3's Avatar
just want to know if anyone has any underbody pics, i need to see it to design the best connectors i can think of. i can visualize it but i have to actuallky see the real thing to think about it
Old Feb 25, 2008 | 11:17 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: does anyone have a pic of underneath, i want to make my own subframe connectors
If you looking for some pictures of under the car here you go. I have a couple of threads. Two that are mine and one that I just posted pictures in.
I made my own SFC's because I did some custom work and there are not any SFC that would fit my application.
When I made mine I used tubing that was 1 3/4" DOM. The wall thickness is .134 The mounting plates on the front are 7ga (3/16") mild steel and the rear mount is attached with a two part mount system. The first part was welded in prior to the SFC and is a U shape part that was welded in 360 degrees and form fitted in there. It was about 7" long. Then the rear of the SFC slid up in there and was welded along the sides and bottom. (hard to explain but worked out great and made for a perfect fit!)
I have a air/hyd mandrel bender. So you can do it different but this was how mine were made.
See attached links for pictures and fabrication of the SFC's
https://www.thirdgen.org/forums/su...-wont-fit.html (what SFC's wont fit longtubes?) (what SFC's wont fit longtubes?) (what SFC's wont fit longtubes?)
https://www.thirdgen.org/forums/ex...html?highlight (My exhaust picture) (My exhaust picture) (My exhaust picture)=
https://www.thirdgen.org/forums/fa...html?highlight (1982 Z28 Silver State project) (1982 Z28 Silver State project) (1982 Z28 Silver State project)=
Let me know if you have any questions or send me a PM.
Brett
Old Feb 25, 2008 | 11:24 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Wow those are quality!! And the exhaust is beautiful!! A+ job!!
eightsixseven
Dec 16, 2024 01:50 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
