which bolts for rear shocks?
Old Feb 29, 2008 | 10:20 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i went online and bought new bolts for my suspension rebuild but couldnt find a set for rear shocks.
any one who knows can you tell me what size bolts i need? and should a local hardware store or home depot be adequate enough to find those bolts?
Old Feb 29, 2008 | 10:54 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: which bolts for rear shocks?
Take a sample with you if you have one and make sure you get a "grade 8" bolt. Also something coated so they will not rust.
Old Feb 29, 2008 | 12:14 PM
Uglybronco's Avatar
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
Seems like I remember bolts coming preinstalled in new rear shocks... on the bottom anyway...
Old Feb 29, 2008 | 12:26 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Yes, most replacement shocks will not install like factory and require a special shock mounting bolt. The replacement shocks should come with the necessary hardware. If you're using replacements and don't have the bolt/hardware any of the major auto parts places should have it hanging in their equivalent of the 'help' section at AZ. Shop around I've seen crazy difference in prices.
If you're re-installing the factory type shocks, you only need a high grade nut to fit the bolt end on the shock.
Old Feb 29, 2008 | 02:29 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Lowes has always had a better selection of nuts and bolts IMHO. Also, their "Grade 8" hardware is coated in something to prevent rust. So they all appear "yellowish".
Old Feb 29, 2008 | 04:39 PM
thewolf's Avatar
Car: 1984 Pontiac Trans Am
Engine: LG4 305 V8
Axle/Gears: 10-bolt LSD
That yellowish coating is called zinc dichromate, if I remember correctly.
My Bilsteins came with all hardware necessary (top nut and bottom bolt). I can check the sizes when I get home if needed.
FWIW, I have had good luck at Westlake (Ace) Hardware finding odd sized bolts and nuts.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
