i need to see some 15's
Old Feb 25, 2008 | 08:05 PM
shoebox1.1's Avatar
hello my names gus i need some help with my car. 1st off i dont have a 3rd gen f body but i am building a 80 model pontiac sunbird H body street strip car. single turbo blow through 4.3 v6! anyway i want to keep the car looking like a pontiac so i took off the weld draglites and im in the process of installing a set of 84-85? trans am firebird alum wheels. 15x7 5 spoke "twisted fan" i call em.. i set one on the car (orange car) and it looks badass! anyway ive 235 60 15 on 7 inch weld wheels now so the rear tire is taken care of. but the front i cant find a 225/55 15 tire! i know the used to make them?! anyone have a pic of a 3rd gen with 235 60 rear and 225 55 front? and/or what about 215/60's on the front? the rear is 26.1 dia and 9.5 section width. a 215/60 should be 25.0 dia and 9.0 section width. help me with these front tires? arrrghhhh!
Old Feb 25, 2008 | 08:14 PM
shoebox1.1's Avatar
Re: i need to see some 15's
Last edited by shoebox1.1; Feb 25, 2008 at 08:15 PM. Reason: Automerged Doublepost
Old Feb 25, 2008 | 08:27 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Can not help you with the tires but I like the sleeper look you are going for.
Old Feb 25, 2008 | 08:38 PM
shoebox1.1's Avatar
thanks! im doing a custom cowl hood for it too. "4.3 litre" script on the side! im even half tempted to get some stock valve covers and do pontiac decals on them. the 4.3 gm corperate engine was available in some late g body pontiacs. so its quasi plausible of a factory vibe
Old Feb 25, 2008 | 08:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
215/65 for front
or
235/60
Old Feb 25, 2008 | 09:42 PM
shoebox1.1's Avatar
where can i get a good pic of 215 65's?
Old Feb 26, 2008 | 08:46 PM
shoebox1.1's Avatar
anyone have any insight on where i can get some silver center caps? thanks
Old Feb 26, 2008 | 08:52 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You can get the silver center caps from Ames Performance Engineering. They are pontiac nuts and sell repop center caps in silver and black. Search the net for them and you'll find their catalog.
My 90 V6 bird came with those "salad shooter" wheels and 215/65 15 tires when it was new. I honestly think you are better off with the 235/60 15s if they don't rub.
Old Feb 26, 2008 | 10:11 PM
shoebox1.1's Avatar
thanks for the input... id love 235s on the front but they will rub bad without question! my buddy had one of these cars back in the day with 15x7 fronts and 225 55 15's and barely rubbed lock to lock.. that would be acceptable i guess. i think im going to look into 215 60's i want the fronts a lil shorter dia than the rears.. im having a hard time seeing the 215's on the front of a 3rd gen bird!
Old Feb 29, 2008 | 04:47 PM
shoebox1.1's Avatar
went with the p215/60/15 on the front thanks for your help
