Upgrading stock susp. Enough parts?
Old Mar 8, 2008 | 11:28 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
I have a stock suspension on my 83 trans am and I want to "start" upgrading it...is this ok for now? Is there anything Im missing or anything here that I dont really need?
Camaro/Firebird 82-2002 Energy Suspension Hyper-Flex Complete Bushing Set
Camaro/Firebird 82-92 KYB GR-2 Front Strut Pair
Camaro/Firebird 82-2002 KYB GR-2 Rear Shocks Pair
Camaro/Firebird 82-2002 Eibach Sportline Lowering Springs
Camaro/Firebird Spohn 82-2002 Lower Control Arms - Std. Tubular with Poly Bushings
Camaro/Firebird Spohn 82-2002 Panhard Bar - Adjustable Spherical/Poly Combo
Camaro/Firebird Spohn 82-92 Sub-Frame Connectors - Single Cat Y-Pipe
Old Mar 9, 2008 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Upgrading stock susp. Enough parts?
The kit will come with pieces you won't need. I'd buy individually as the need arises.
JamesC
Old Mar 9, 2008 | 01:47 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Which ones should I order right now?? I was also thinking about a front end rebuild kit. Which bushings should I really get replaced?
Old Mar 9, 2008 | 01:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the only things you will probably use for the kit are the front a-arm bushing and the trans mount.
other than that, you may use the swaybar end links
on top of your list
get a torque arm bushing or aftermarket torque arm, a steering brace too, and if your ambitious and dont mind the extra work, poly motor mount inserts too
Old Mar 9, 2008 | 02:45 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
get a torque arm bushing or aftermarket torque arm, a steering brace too, and if your ambitious and don't mind the extra work, poly motor mount inserts too[/quote]
and speaking of braces strut brace and SFC. but you probably know that.
Old Mar 9, 2008 | 04:26 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Read the thread right below yours called "Re-doing stock suspension"
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
NinjaNife
Aug 23, 2015 11:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
1nastygta
Aug 8, 2015 07:38 PM
