Wheel nut torque specs.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
What are the torque specs for the wheelnuts?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Wheel nut torque specs.
IIRC, the manual says 80.
JamesC
JamesC
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Dosent it depend on the type of wheel? Stock vs Aftermarket and the type of alloy. Steel vs Alumnium
OK, stock aluminum's, 16 inch.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Torque spec doesn't care if it's steel or aluminum. Torque spec is based on stud diameter. The 12mm stud is similar to the old 7/16" studs. 80-90 foot pounds is fine. Never use an impact. You can overtighten and stretch the studs plus you'll curse and swear when you need to fix a flat with a tire wrench on the side of the road.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
If I dont feel like charging up the compressor, I will just use the 4-way. I put them on as tight as I can. Always easier to take them off.
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
A 4-way as tight as you can get it???? I'm a 170lb weakling, but I think I could break a stud off with my 4-way pretty easily.
Engine: 4++,350 & 305 CIs
I'm a kinda big fella and I can over tq wheels with a quarter drive ratchet. no joke.
ALWAYS use a TQ wrench.
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
I use my impact all the time... Works fine for me. You just gotta know how to do it, I used to change tires all day long for a job, so I used the impact alot. Untill the changed the rules and made us use a torque wrench!
u just cant sit there and let it keep hammering lol or the stud is gone.
( saying this to not discourage the use of an a impact) Torque sticks are actually good 2
I do use a impact to run lug nuts down everyday to.
Im just saying you need to check them with a TQ wrench..
Axle/Gears: 3.23's
Car: '86 v8 sport coupe hatchback
Engine: 305CI
Axle/Gears: stock... looking for low gear posi
you dont need to torque them, the impact is overkill its fine to use the impact to spin the nuts on all the way if its allready out but barring use of a torque stick i wouldnt recomend hammering it on trying to tighten them with it (not because you cant because it can be a real bitch to extract a broken stud) that said i allmost allways use either a 4 way or 2 foot breaker bar as tight as i can without jumping on it or anything thats about 80-95 ftlbs wich is fine for pretty much any car unlike say...heads lug nuts arent really an exact science
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I use a 100ft/lb torque stick and forget about it. That'll put it between 90-100 ft/lbs, never had a problem. Anywhere between 80-100 ft/lbs is fine.
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
At Discount tire, we torque all camaro/firebirds at 100 ft/lbs according to a certified chart thats updated each year. Im sure 80 would be fine though. The wheels shouldnt fall off or anything.
Car: 89 Firebird
I put them on at 75ft.lb because that is as high as my torque wrench goes. That is not tight enough, I know. I have to retorque them a second time a few days later (the nuts all ways turns a little bit) and doing that has been good for as long as I have owned my Torque wrench, since 2002 or 2003.
If your only going to do it "One time" yea you would want to do it to 100ft.lb.
I don't want to break a stud or sink the nut through the wheel.
When I was in japan there was a rash of wheels falling off cars and trucks due to a faulty impact wrench at the hobby shop on base. It went on for about a year untill they figured it out.
morrow
Jan 13, 2024 12:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
