Car has lean and rub.
Old Mar 19, 2008 | 11:25 PM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
I have an 86 Z28 that has a lean to it. Im not sure when it started but its bad, in the front the passenger side sits 2 inches lower than the drivers side. I believe that this is also what is causing the rear to be off a bit to form side to side. When I turn hard left the passenger tire rubs hard. Im not sure if this is a suspension problem or a frame issue. I figured it was suspension since it was really only the passenger front that was affected. I need help on sorting out what the problem might be. Thanks in advance.
Old Mar 20, 2008 | 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Car has lean and rub.
I'd suggest a visual inspection. Now.
JamesC
Old Mar 20, 2008 | 11:41 AM
86z28305's Avatar
Good Advice. Not sure where to start I looked the other day and I wasnt sure what was supposed to look like what and all that.
Old Mar 20, 2008 | 12:08 PM
Well, the car has 2 essentially identical sides, the right and the left.... one is broke.... the right side is suposed to look like the left side.... fairly simple and straightforward really.
It might just be that the spring on the right is worse wore out than the one on the left. Or it might be that something is bent.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
