Steering Box Fitting Size
Old Mar 21, 2008 | 05:56 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I do not need to know the size on the pump i already know what i need there.
I'm wondering if its standard or metric? 16mm or 18mm? 5/8-18in?
I cant use the factory line with my summit pump so i figure i can make a braided hose setup using -6AN. I can get a fitting for the pump but i need to know the size on the box.
Thanks.
Old Mar 21, 2008 | 06:18 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Steering Box Fitting Size
Check with any of the -AN fitting companys, they have them..
Old Mar 21, 2008 | 06:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Metric 16 and 18mm. Aeroquip and a few others sells the proper adapter fitting to convert to AN hoses.
Old Mar 21, 2008 | 06:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the fitting on the steering box on my car were 16mm1.5 with o-ring and 18mm1.5 with o-ring
what are you using for hose? I used russel powerflex or whatever and am having a heck of a time getting them to seal completely. russel/edelbrock blows!!!
Old Mar 21, 2008 | 09:10 PM
TTOP350's Avatar
I found this searching for parts for my 70 bird.
http://www.detroitspeed.com/productp...g_met_prod.htm
Old Mar 22, 2008 | 08:33 AM
Stevo's Avatar
Great, thanks for the help guys. I had searched this site but it was last talked about in 02, so i figure id try to get a more clear answer. Appreciate it.
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
toronto formula
Nov 10, 2015 06:17 AM
backtothe80s
Sep 5, 2015 12:39 AM
knight72
Aug 10, 2015 09:32 PM
