Cracking/Clunking steering noise
Old Mar 29, 2008 | 01:23 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
Hi,
today i started up my camaro and drove it out of the garage. i noticed a loud cracking/clunking/squeaking noise after a 1/2 turn of the steering wheel in either direction. with the engine off it get's really hard to turn. it sound's like it's coming from the wheel area. besides i noticed that my ps/ pump hose is leaking bad. about a 4 in. puddle in 1 minute....
maybe it's something in the steering box? or did i mess up something?
parts that are new: struts, strut mounts, shocks, wheel bearings, a-arm pu-bushings+ball joint, pu sway-bar endlinks, brake discs+pads
the sound startet after replacing the struts, shocks and a-arm bushings+ball joint.
thx all,
nebu
Old Mar 29, 2008 | 03:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Cracking/Clunking steering noise
if the hoses are leaking you hould get them fixed.
how bad does the cracking/creaking sound? is the steering box tearing off the frame? it happens, check it out. Maybe time for a wonderbar
Old Mar 29, 2008 | 04:09 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
i'll check that tomorrow with the front in the air. maybe i can get a video, so you can hear how bad it is. (after refilling the reservoir...
nebu.
Old Mar 30, 2008 | 11:03 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
i added som ps fluid and no more cracking
but you're right, 86TA. the steering box is tearing off. what is a good wonderbar? umi?
is this the hose i need?
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
