Help me pick out a Mickey Thompson drag radial
Old Apr 3, 2008 | 01:45 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I have the stock wheels for a 1991 firebird, I think they are 7" wide, I'm not sure though. Could you guys help me pick out a drag radial that would work in my application? I'm somewhat on a budget right now. Any help would be appreciated, I'm running the stock wheels for a stock sleeper look BTW.
Old Apr 3, 2008 | 02:41 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: Help me pick out a Mickey Thompson drag radial
I would go with a P255/60R15, its 27in tall and recommended for a 7-9in rim. That tire would be as big as you would want to go with a 7in wide rim.
Old Apr 3, 2008 | 02:44 PM
automorph's Avatar
Car: 89 Trans Am
Engine: 3.1 V6
Nitto 555R, Mickey Thompson or Hoosier all make a 245/50/16..........if 15" they have a even wider tire 275 is what Buick guys use
Nitto 555R good in rain, decent wear, decent performance
Mickey Thompson great performance, wear fast, rain???
Hoosier ???
BF Goodrich crap in rain, decent performance, wear fast
Old Apr 3, 2008 | 03:09 PM
Car: 91 Firebird
Engine: Turbo 355
Where do I find this tire and order it? I'm not the most internet suave person...
Old Apr 3, 2008 | 10:26 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
how much power?
the radials really arent the best at the track for a stick shift car, but they still give great performance on the street.
if they are track only tires, id look into a set of "stiff" wall slicks.
Old Apr 4, 2008 | 05:26 AM
jbenge's Avatar
Mickey Thompson has a dealer locator, you just put in your zip code. Most chain stores like discount tire, Big O ect can get BFG, MT, you just will have to special order them. If there are any speed shops around your area they may even have some in stock.
http://www.mickeythompsontires.com/locator.php
Old Apr 4, 2008 | 07:24 AM
AC's Avatar
AC
Car: Used to drive a camaro
Summitracing has a decent selection of all the brands just mentioned and more. Goodyear has DOT slicks as well. I myself and gonna give Hoosiers a shot once the weather warms up here and I need track tires. But I'm in the 17" wheel selection...not as many as you'll have to select from.
Old Apr 4, 2008 | 08:10 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i agree with stage 20.. if you plan on tryin to get the fastest times at the strip with these tires, dont bother, at best you will hit a 1.6 60ft.. i've never heard of anyone going faster than that with a stick and small radials (>275)..
at the track, i could only muster a 1.810 best with 275/50-15 MT radials.. then i got a set of hoosier QTP's and i'm not looking back.. when i get the funds, i'll be running hoosier prostreet radials up front and my qtp's in the back for street tires.. no money for front rims and tires yet..
et streets or hoosier qtp's would be a better option for traction.. but i have heard that the hoosier radials are supposed to be better than the MT's.. alot of mixed testimonials..
Old Apr 4, 2008 | 05:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
on a stick car the hoosiers will work better than the mt. the sidewall is much softer and there isnt as much radial construction in the tire(hence they are lighter)
i would choose a qtp over a MT et street anyday.
if you had an automatic, the MT radial is a bad bad boy.
good luck. you really cant go wrong.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
