Center of Gravity
Old Apr 7, 2008 | 02:43 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
Center of Gravity
hi
for what served Center of Gravity ?
Center of Gravity served for intall "ladder bar"
Old Apr 7, 2008 | 07:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Center of Gravity
?? Not really sure what you're asking because you never really asked a question.
If you want to find center of gravity, you need to weigh the car a couple of times. The first part is easy. Weigh the car with the front wheels on the scale. Weigh the cars with the rear wheels on the scale. Weighing the car with all the wheels on the scale should equal the front and rear weight combined.
Knowing the front and rear weight, a front to rear weight ratio can easily be calculated. Third gens are all nose heavy.
The second part of finding the center of gravity is the CG height. This takes a bit more work and I'm not going to type it all out. Just go read this web page on how to figure it out. Typically the CG height is guessed at camshaft height which is close enough.
http://www.longacreracing.com/articles/art.asp?ARTID=22
Old Apr 7, 2008 | 07:59 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
for install "LADDER BAR" necessary center of gravity
Old Apr 7, 2008 | 09:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You have very few choices for IC location and CG isn't a factor you can deal with using ladder bars.
Depending on how many holes are on the front mount, install the front mount so that the bottom bar of the ladder bar is parallel to the ground when in the middle hole.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
