Rear shock upper mount plates - reinforcement needed?
Old Apr 8, 2008 | 12:15 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I stripped most of my interior down for cleaning and carpet replacement last weekend, and after pulling the rear carpet, I noticed that a little bit of dirt and grime seems to be getting in around the rear shock mount plates. It looks like the factory body sealer has separated where the panels meet, seemingly from vibration or movement. Has anyone else had this problem? I'm thinking of welding the plates to the car to reinforce them, has anyone else done that? If nothing else, I plan to re-seal it with some silicone sealant to stop the dirt from getting in.
This isn't a pic of my car, but these are the seals I'm talking about:
Old Apr 8, 2008 | 03:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear shock upper mount plates - reinforcement needed?
is it dirt of just that wonderful nasty black goo sealer they used? I had the same sealer in that area in mine. If you want to weld them thats cool, but so long as nothing is rusty you should be good to go
Old Apr 8, 2008 | 05:43 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
It's definitely road grime, the body sealer in that area is white. Some of the grime had made it's way down to the rear seats, which was a total pain to clean off. There is no rust, but i'll have to grind/scrape off the original body sealer, so I can weld there.
Old Jul 21, 2009 | 10:40 AM
MadMax1983's Avatar
My shocks broke right through there... anyone seen a repair kit?
Old Jul 24, 2009 | 08:45 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Weld 'em up. Gas shocks will pull them out. Sounds like they have started.
I had a fabricator weld mine up YEARS ago. I don't know of a kit, anyone else??
Old Mar 11, 2010 | 11:46 AM
jpw83's Avatar
Car: 83 CAMARO
Axle/Gears: 3.43
What/where did you weld?
My 83 RR shock pulled out from the body. The metal there is torn up. I'm trying to find a good way to reinforce the shock mount. Maybe a repair kit exists but I havent found one.
Old Mar 11, 2010 | 02:17 PM
Flip 2's Avatar
Engine: C5 LS1
You just need to have someone reinforce the whole area around the top mount. Do both sides. Find someone who does fabrication work on drag racers or oval track cars. It will be a walk in the park for them.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
IROCZ1989
Jan 24, 2016 03:55 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
