front springs
Old Apr 9, 2008 | 01:43 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
front springs
hey guys i have an 82 camaro that use to have a 6cyl and the guy i bought it off threw in a 350 and now the front end is sagging pretty bad cause the guy left the 6cyl front springs in..........
my question is
whats the easiest way to pull the front springs off???
i read the article in the tech forms but it dosent make sence the guy is talking about struts?!?! (not shocks no struts)i dont get it?
thanks,
john
Old Apr 9, 2008 | 04:20 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: front springs
my question is
thanks,
john
Hmmm, did you try a yet, this has been covered a million times B4
It's pretty easy:
Get some spring compressors (the kind that go on the inside of the spring), and separate the spindle from the ball joint. Comes right out, replace, put back together.
Now there is a little more to it than that, but if you do a search, you'll get some more details
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
