spohn sway bar set or your preferenece
Old Apr 8, 2008 | 04:43 PM
Method_z28's Avatar
Car: 92 camaro z28
I got the sportlines....lca's w/ relocation brackets....umi SFC adjustable torque arm and panhard rod....tds wonder bar. My question is what sway bar set do you think I should get with this set up. I heard a lot of people saying the spohn set is way toooo big and will cause oversteer. I couldn't tell you whats on the car now off the top of my head but I wanna replace it anyway. Oh yeah I got KYB shocks/struts too. Any information and pricing will be very appreciated.
Old Apr 8, 2008 | 09:57 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: spohn sway bar set or your preferenece
What size you have now? Alot of people like the 36/24 combo. Some like a smaller rear bar. I'd just get a couple of sets of bars and try them out. I have a 36/Spohn 25 and it's too much rear bar. Causes over-steer under throttle or when in a hard tight turn. I'd reccomend spending the money on Some KONIs. They'll probably help more than sway bars.
Old Apr 10, 2008 | 01:27 AM
86irocterror's Avatar
to save on money i would say original sway bars in 36mm front and 24mm rear. if money is no concern.....get what i have hotchkis front and rear bars......very well matched and no over or understeer caused by the suspension(only throttle causes it now.... ) but they are around 500 bucks for a set they are 1 7/16" inch front and rear is 1" and it made my car very neutral
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
