Alittle help needed to an old question please ?
Old Apr 14, 2008 | 04:35 PM
mrdaydreamr's Avatar
Yes another wheel and tire question.I'm a newbie here and i've searched the site but i'm still don't have an answer.My question is, i have a 92 rs and i want to put new wheels and tires on it(they are 16's now going to 15's) I just wanted to know if i put a 15x10 wheel (old school)with 4"backspacing and a 265/50/15 tire on the rear will it rub on the frame ? I don't mind if it sticks out pass the fender allittle,i just don't want to rub the frame.I want to stick with a 15x10 rim(W 4" BACKSPACING) because of the deep dish look, I could go down to a 255/60/15 tire but i'm not sure if the rim is to wide for that tire? what do you guys think ???? THANKS FOR ANY HELP YOU CAN GIVE ME !!!
Old Apr 14, 2008 | 04:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Alittle help needed to an old question please ?
no rubbing at all, the will stick out over 2" from the side of the car, not good
Old Apr 14, 2008 | 06:17 PM
If it's going to stick out 2" from the fender,should i change the backspacing from 4" to 4.25"or 4.50" (to pull the rim inward) or will that make it rub on the frame ? I really wanted to use a 15x10 rim but i don't want it to stick out 2" . If i can't get a 15x10 rim to work and i go to a 15x8 rim should i change tire size also(from a 265/50/15 to a 255/60/15) and can i still use a 4" or less backspacing ? THANKS AGAIN FOR ANY HELP YOU GUYS CAN GIVE ME !!
MustangBeater20
Oct 29, 2022 09:20 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
