Tires rubbing on inner fender with new Moser rear end
Old Apr 21, 2008 | 02:35 PM
Praetorian27's Avatar
Car: 82 Z28
Engine: 350 bored .030 over w/ 6-71 Weiand
Transmission: Turbo 400
Axle/Gears: Moser 9" w/ 4.56 gears
I put a Moser 9" rear end in my Camaro, and the rear tires are hitting on the inner lip causing damage to the edge of the tire. I really don't want to put spacers in the springs...don't want that high rear end look. Are there blocks or something like that to put on the rear end itself to stop the suspension travel before the tire makes contact with the fender?
Old Apr 21, 2008 | 05:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tires rubbing on inner fender with new Moser rear end
you can roll the fender lip, that really helps. Drag bags will help with limiting the movement of the rear suspension
Old Apr 21, 2008 | 06:23 PM
Car: 82 Z28
Can you roll the fender lip without damaging the paint?
Old Apr 21, 2008 | 07:05 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
use a heat gun and roll the lip with a baseball bat in between the tire and the lip and push down....very easy to do.
Also my moser 9" was spot on, are you sure you ordered it in the right width?
Old Apr 21, 2008 | 07:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
my moser 9" is about 1/2" narrower overall, i didnt order it that way. Maybe just production tolerances? that 1/2" is killing me
Old Apr 21, 2008 | 09:22 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
If the 9" is a 1/2" shorter now and you are hitting the quarter panel lip, how far did your tires stick out with the factory 10 bolt? Is this a spring height issue?
Old Apr 21, 2008 | 09:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
talking to me?
im rubbing on the inside of the wheel well, by the springs, control arm ect. My wheels do not stick out at all, they are tucked up nicely, a little to nicely at the moment
Old Apr 23, 2008 | 07:20 PM
Car: 82 Z28
This will give an even radius?! How the heck do you do it without making high and low spots?
Old Apr 23, 2008 | 09:24 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
sounds like you need to center the rear in the car. adjustable lca's if you dont have them.
not the 1st time ive heard of this happening, if its getting into the 1/4 panel in the front.
Old Apr 28, 2008 | 06:24 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Take your tires off, look for bare metal, hammer away.
Old Apr 28, 2008 | 10:23 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Also, are they rubbing on both sides? Cause if not the rear is not centered properly. This has nothing to do with LCA relocation brackets. It's the panhard rod that needs to be adjusted.
Also, with a moser rear you should have longer wheel studs so a 1/4" spacer on each side to make up the 1/2" narrower rear is no big deal.
Last edited by camarojustin; Apr 28, 2008 at 10:26 PM. Reason: Automerged Doublepost
Old Apr 29, 2008 | 11:36 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Yep, I had my 10 bolt centered pretty well, then installed the moser 9 and had to move it another 1/2 inch.
What size tires?
Nice car btw.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
