468 BBC 85 .. Race front suspension
Old Apr 29, 2008 | 12:57 PM
Tranzamman's Avatar
Car: 85 Firebird
Engine: 468 BBC
Transmission: Turbo 350
Axle/Gears: 3:73
So this car has been a working project for the last 6yrs ... we ordered springs 3 yrs ago now when the engine is in i started to put the springs in ... unfortuantely these springs are 10 inches longer than the factory springs and much stiffer --- on my 4rth gen the springs are mounted to the struts -- Has anyone swapped to a 4rth gen style suspension or a better design suspension ?
Old Apr 29, 2008 | 07:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 468 BBC 85 .. Race front suspension
I run Koni SPA1 struts and unaltered Moroso BBC trick springs.
Old Apr 30, 2008 | 07:02 AM
Tranzamman's Avatar
Car: 85 Firebird
Engine: 468 BBC
Axle/Gears: 3:73
How did you get the springs into the a-arm ? through the back or front ?
Old Apr 30, 2008 | 08:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I used a spring compressor that fits inside the spring and slid them into place. Reconnected the ball joint to hold the a-arm and removed the spring compressor.
customblackbird
Aug 15, 2021 10:16 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
