Rear sway bar question
Old Apr 26, 2008 | 07:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I currently have a hotchkis 1" rear bar, it seems to be bent a little differently than stock, and this is causing headaches with my coil-overs and my new rear.
From what i understand, bigger is not really better for the rear sway bar for a handling application, right now the back end will slide out on me pretty easy, no 180's but a bit loose, should i be looking for a smaller bar? any size recommendations?
Old Apr 27, 2008 | 01:19 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Rear sway bar question
Going with a large rear sway bar like the one you installed often causes oversteer (when the back of the vehicle wants to pass the front when braking or accelerating). To fix this, just install a smaller rear sway bar. I plan on just going with the WS6 sway bars (36mm hollow front, and 24mm solid rear) for my IROC. It's a proven setup and one of the cheapest applications available.
If you have a small front swaybar, it might just be that you setup isn't balanced. What I mean is if you have a small 30mm front bar and a huge 25.4mm (1in) rear bar, that might be your problem.
Old Apr 27, 2008 | 01:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i have the hotchkis front bar too, 1 7/16, a little bigger than 36mm i think, its a big one. I think im going to try to find a smaller rear bar and see what happens
Old Apr 28, 2008 | 09:48 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I have the Spohn 25.4 rear and the WS6 36 front. My car has problems with oversteer as well. If I ever get the time, I'm going with the WS6 24mm.
If I did the math right, the 1 7/16 inch bar is a 35.8mm.... pretty much 36, lol.
Old Apr 28, 2008 | 07:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
36.5mm actually, same difference
Old Apr 28, 2008 | 07:14 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yeah, you're right. I messed up somewhere in the math.
Old Apr 29, 2008 | 11:49 AM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
If you are running stock spring rates the 24mm bar is good but if you have installed stiffer springs the 24 may still be too big. I have 150# rear springs and went from a 24 to a 19mm rear bar to get rid of the oversteer.
Old Apr 29, 2008 | 05:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i have rear coil-overs with 170lb springs, so should i be looking at a little bar?
Old Apr 29, 2008 | 09:35 PM
Souseless's Avatar
Car: 89 WS6
In order to reduce the oversteer you will need to use a smaller sway bar at least that is the easiest and cheapest way.
Old Apr 30, 2008 | 04:34 PM
UMI Performance's Avatar
We have found the larger rear bars to cause under steer... we have bars in development now and we will be offering a 22mm solid rear. The 25mm (1") is to stiff and causes the problems you are seeing.
Hope that helps,
Ryan
Old Apr 30, 2008 | 10:59 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I have the Spohn 1 5/6" front bar with a 23 mm rear one, and it feels pretty good. I dont have alot of over or understeer.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
