suspension replacement, looks like i installed a lift kit in the rear!
Old Apr 30, 2008 | 08:11 PM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
Like the title says, I've replaced the entire suspension, and i've used the koni yellow/eibach pro set up. The front is sitting way higher than stock, clearance from top of tire to outer fender lip is probably 5".
I've done a search, and I'm going to assume that my springs were indexed improperly. I also discovered in my search that there are certain bolts that must be tightened with the suspension unloaded and some with the suspention loaded.
Any information as to which bolts to tighten and when would be a huge help.
I've also used new upper spring isolators. How much of an increase does that account for?
Last edited by jminton; Apr 30, 2008 at 08:11 PM. Reason: I meant lift kit in the front. Been a long day...
Old Apr 30, 2008 | 09:00 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: suspension replacement, looks like i installed a lift kit in the rear!
I have the same set-up on my car, and you can see how it sets (click pic for more). Does your's set higher?
Old May 1, 2008 | 05:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Little of nothing. Eyeball the indexing. Make sure the springs are seated in the pocket.
JamesC
Old May 1, 2008 | 11:25 AM
jminton's Avatar
Car: 1985 IROC
Does anyone have, or can link me to a picture of a correctly indexed spring on the A-arm? I would appreciate it.
Old May 1, 2008 | 12:15 PM
402 GTA's Avatar
Car: 86 GTA
Engine: 402 cbb
Transmission: th350
Axle/Gears: 9" 3.50
If you drive it for a couple days it might loosen up and sit at the right height.
Old May 1, 2008 | 06:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you have 5" of space there, the springs are not seated on something. Have you moved the car yet?
Old May 1, 2008 | 06:55 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
There are two small (1/4") holes drilled in the spring seat in the front A-arm. These are used for proper indexing. The end of the coil should sit in the middle of these two holes. If they're not indexed you have to take them back out again and put them in correctly.
Old May 2, 2008 | 11:22 AM
jminton's Avatar
Car: 1985 IROC
//<86TA>\\ :
Yep, I've been driving the car for a week or two now. I've even gone through a torque test on all the bolts between then and now.
Darkshot :
Looking at the picture in the "Front Suspension 101" thread in the sticky section, are you referring to the 2 holes that are closest together, or the 2 holes which are across from each other and appear to be on a "raised platform"?
Old May 2, 2008 | 11:28 AM
JamesC's Avatar
The two closest together (under the number "12" in the photo).
JamesC
Old May 2, 2008 | 06:56 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
If you used "new" upper spring isolators (part # 10290379), then they are 4th gen ones, and they are thicker that the stock 3rd gen isolators.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
drathaar907
Aug 6, 2015 04:20 PM
