Coil overs
Old Apr 8, 2008 | 11:41 PM
SuperChevyZ28's Avatar
Coil overs
I am debating on putting Front and rear coil overs on my 1991 Z28 Camaro, or else 1.2 lowering springs and real good shocks. I want it to be good on the Strip and corners, so are the coil overs worth the extra money???? An advise would be apprecaited.
Old Apr 8, 2008 | 11:54 PM
Stephen's Avatar
Car: 87 GTA
Re: Coil overs
I'm a big fan of the Ground Control stuff for autox use.
Old Apr 9, 2008 | 06:12 PM
Re: Coil overs
So you are saying to go with the coil overs. I seen a Front kit buy Sphon that will let you lower it to 3", and also a rear kit from Sphon, but it did not mention how much you can lower the rear, dose anyone have a clue, i am guessing 3" as well
Old Apr 9, 2008 | 06:18 PM
Stephen's Avatar
Car: 87 GTA
Re: Coil overs
Ground Control stuff isn't true coil over, but rather weight jacks, that allow about 3" of adjustment, corner to corner.
To coil over the fronts, you'd hafta go with different struts completely. Weight Jacks allow you to retain your struts & adjust the springs independently.
Old Apr 9, 2008 | 07:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Coil overs
not entirely true, the front kit will work with just about any strut, the rear kit uses a special shock.
Old Apr 9, 2008 | 07:57 PM
Stephen's Avatar
Car: 87 GTA
Re: Coil overs
Actually, I was COMPLETELY WRONG. Dunno why, but I keep thinking we have coil-over struts, when we don't. I should know that by now. Damn sure done enough to know better..
Where is the "Hi. My name is Stupid, what's yours?" emoticon?
Old Apr 9, 2008 | 08:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Coil overs
will this work
or maybe this
Old Apr 9, 2008 | 09:05 PM
Re: Coil overs
So what kind of suspension would you say is the best for the strip, corners, and street use????
Old Apr 9, 2008 | 11:59 PM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
Re: Coil overs
thread-jack: are weight jacks (the springs in particular) practical for street use? Or at least are they civilized enough for street use?
Old Apr 10, 2008 | 12:32 AM
Stephen's Avatar
Car: 87 GTA
Re: Coil overs
That mainly depends on 2 things...
They are available in many different lb ft ratings.
And the shocks you are running.
So, you can just a little firmer than stock, or...Why use springs at all? Not that bad, but you get get them in a wide range & Ground Control can advise you better than I can in what to select, based on your intended use, which shocks you have, etc.
What Weight Jacks amount to are adjustable spring perches.
I like the adjustable caster/camber plates too...
Old Apr 13, 2008 | 03:29 PM
Kandied91z's Avatar
Re: Coil overs
coilovers change the feel of a thirdgen completely... i would highly advise against it.
Old Apr 13, 2008 | 08:38 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Coil overs
From what I understand coilovers will also drastically cut down the available width you have to front tires.
I'd go weight jacks if you actually plan on corner weighting the car for a desired height and tracking it. Otherwise just stick with some decent springs under there.
Old Apr 15, 2008 | 05:48 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: Coil overs
has anyone done weight jacks with c6 rims? is there any problems at all with fitment. I was thinking about coilovers too but weight jacks sound like less of a hassle. also how much drop can you get from them or is it dependant on the springs you choose. kinda nice the ground controls are Eibach. also anyone got any recommendations on shoocks and struts? mine will be mainly street since the closest track would require a 12 point cage to run any decent numbers since mine is a vert.
Old Apr 15, 2008 | 05:53 PM
Stephen's Avatar
Car: 87 GTA
Re: Coil overs
The weight jacks won't take up any more room than the standard coils, since the fit i the spring pocket like stock.
Drop is more dependent on where you set the springs too, with regards to ride height.
Choose your struts/shocks first, then Ground Control can match the springs, & intended use, better.
Old May 2, 2008 | 04:08 PM
Re: Coil overs
i thought coil overs take less room then the stock suspension, and gives better handling and gets rid of alot of weight
Old May 2, 2008 | 04:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Coil overs
the coilovers that spohn sells install over the strut, thus taking up a little more room that just the strut.
here
see?
Old May 2, 2008 | 06:19 PM
jstoltz's Avatar
Re: Coil overs
I thought all coilovers install with the coil over the strut not just Spohns'
Old May 2, 2008 | 06:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Coil overs
that is absolutely true, i didn't mean to mislead, i just wanted to differentiate from the ground control spring setup
Old May 2, 2008 | 06:55 PM
jstoltz's Avatar
Re: Coil overs
oh
one other question is the ground control price for all 4 needed or per pair?
Old May 2, 2008 | 07:24 PM
jstoltz's Avatar
Re: Coil overs
I was also wondering Stephen do the caster/camber plates par up to say Spohn's or exceed. They look way different and never saw them until this thread.
Terrell351
Jun 13, 2021 01:13 PM
Derick15
Sep 17, 2016 05:28 PM
lt1z350
Aug 28, 2015 05:57 AM
lt1z350
Aug 23, 2015 08:33 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
