coil spacers?
Old May 20, 2008 | 07:44 PM
88bird?'s Avatar
Car: 1988 Pontiac firebird
Engine: built 350
Transmission: 700r4 built up to 600hp
Axle/Gears: stock for now
coil spacers?
Well me and my friend were driving home after school today, and we seen a 1st gen firebird that was jacked up in the rear, and i said i would like to do that to my car cause my tires rub (i know, i will be rolling my fenders soon) and he said they were only coil spacers, does anyone know where i can get them?
Old May 20, 2008 | 08:02 PM
karl's-92'-z28's Avatar
Car: Too many cars
Re: coil spacers?
I think most parts stores carry them, I wouldn't really recomend them. Its just an easy fix & not the right fix.
Old May 21, 2008 | 08:38 AM
88bird?'s Avatar
Engine: built 350
Re: coil spacers?
Well im not using them as a fix, i will be rolling my fenders, but why wouldnt you recommend them?
Old May 21, 2008 | 05:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: coil spacers?
are your current springs stock? if so they are sagging really bad by the sound of things. Why 'band-aid' this problem? pick up a set of new iroc springs from spohn for like 125 bux and be set. Or if its nota drag car, some ebiach prokits springs, they will raise the rear of your car if im picturing this correctly.
what size tire are you running
pics?
BTW first gens have leaf springs in the rear, no coil spacers there.
Old May 21, 2008 | 10:15 PM
Car: Too many cars
Re: coil spacers?
I would jus roll the fender & save the money. Cause if they are not sitting right they might just come shooting out ilke a bullet & cause damage to something else. There will be alot of pressure & your coils may bind. Just my oppinion.
Old May 22, 2008 | 06:07 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: coil spacers?
Also, if you raise the rear, you'll need and adjustable panhard bar, just like you need one when lowering.
I have seen spring spacers designed for 3rd gens on ebay.
I would replace your springs if they are old 1st, then see if you'll still need the spacers.
Old May 22, 2008 | 08:18 PM
88bird?'s Avatar
Engine: built 350
Re: coil spacers?
pics?
The springs in the rear are rather new, i have 275/50-r15 bfg drag radials, it doenst sag, i just like the looks of it being jacked up a little bit, also its a third gen, i just SEEN a first gen jacked up and liked it.
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
