MT sportsmans vs et streets
Old May 29, 2008 | 12:42 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Currently have sportsmans on my car 29x12.5. How much better would et streets be on the road? I'm shreddin em with only 3 psi.
Old May 29, 2008 | 10:32 PM
Finetunedz28's Avatar
Re: MT sportsmans vs et streets
I ran sportsman pros for a few years. Never below 16lbs of air. Et streets hook better. But suck in the rain.
Old Jun 1, 2008 | 06:34 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
any pics? i put a 29x12.5 on my car and it looked like a woods truck.
on another note, if you suspension is working right, the tires are a nice piece.
i ran several sets of 28x10.5's and they worked really well.
3 psi in the tires is asking for a train wreck. you really need at least 12psi in the tires, depending on the vehicle weight.
Old Jun 1, 2008 | 07:18 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
They stick out a little bit. The tread is under though. I also have a 9" and its 1/2" narrower than the stock rear. They have a 13.1 width, the same size et streets are 12.4 IIRC.
I have solid control arms and tq arm. shocks are old stockers. tire pressure is up around 30 I think. My pinion angle is also off.
When I said 3 psi, I meant boost, but its actually around 4. Making around 550-600 flywheel hp.
Stage are you using gen III engine?
Attached Thumbnails MT sportsmans vs et streets-01-06-08_2012.jpg   MT sportsmans vs et streets-01-06-08_2013.jpg   MT sportsmans vs et streets-01-06-08_2014.jpg
Old Jun 1, 2008 | 09:27 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
30 psi is your issue. they need to be in the 13-18psi range.
i ran mine at 15-16 most of the time on the street, and 18 at the track.
Old Jun 2, 2008 | 11:26 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Well, I'll bring it down to 18 and see how it does. It was leaving a good footprint when I burned out, so I didnt think it was an issue.
They also spun when I wacked it in third, at low speeds, or when I downshifted into second, so I didnt think any wrinkle effect would help either, since I didnt think I was really shocking the tires very hard.
seiplentz
Aug 19, 2019 06:02 PM
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Night rider327
Sep 16, 2015 02:20 AM
