Road racing + brake proportion valve
Old Jun 3, 2008 | 10:28 PM
Parts4sale's Avatar
Would you only need one? and would this be a better idea then runing a stock type prob block? does anyone on here run something like this? if so how do you have the cars line presser front/back set up....
Old Jun 6, 2008 | 11:20 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: Road racing + brake proportion valve
The most common move, is to go to the 4th gen Master, run the front lines straight to a T, and then put the prop-valve in on the rear line. This gives you full pressure to the front, and then you dial down the rear pressure to fit what you car and brakes want.
You could also mess around with diffrent MC bores from factory cars, and aftermarket stuff like wilwood to get the pedal feel and pressure you want.
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
