CORRECT SPRING I HOPE ????
Old Jun 8, 2008 | 12:38 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Last year i posted here to what springs to put in my 82 z that ive added 16 inch wheels. to, --has orig springs at 240,000 miles.--- And i decided on the iroc moog springs.----I put in the rear ones [5665] about a week ago and i swear its sitting to high ??? I watched for other irocs here but you dont see them when you really need too. lol, to compare mine too.--Who here has installed these and have no problem with hieght and if possable give me your tire to fender clearence.------ COULD IT BE, that after i chang my front to [5662] it will help the stance [height] in rear ??
Old Jun 8, 2008 | 12:47 PM
Stephen's Avatar
Car: 87 GTA
Re: CORRECT SPRING I HOPE ????
After 240,000 miles, your stock springs were probably sagged & your comparing the new cars ride height to your old ones.
Old Jun 9, 2008 | 09:28 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
They do sit pretty high. It helps if you take out the isolater, use some heater hose on the top coil instead. The 5662's should raise the front back up as well.
Old Jun 9, 2008 | 10:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm using the 5665's. I removed the isolator and replaced with radiator hose. I also cut a bit of the coil. Fairly satisfied at 27 3/4". The 5662's are at just under 27", which gives the car a bit of a rake. I've read that OE ride height is 27 1/2".
JamesC
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
crazynights
Aug 21, 2015 06:53 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
86White_T/A305
Aug 17, 2015 12:16 AM
