replacing idler arm
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
replacing idler arm
anything i need to know? any special tools besides a pickle fork i need? Also I read i need to put it in the exact same spot (how do i do that) and that it needs to be paralell to the pitman arm axis or something can anyone clarify on that???
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: replacing idler arm
mark around the old arm with a pencil before you remove it, then put it back in the same spot and you are good.
the bolts that hold the arm on can be accessed through the passenger wheel well, the front of the liner needs to be pulled back, or remove the whole thing and then you will see the holes in the frame where you can get the wrench in.
Car: '89 IROC-Z
Engine: 355
do i need the steering linkage installer to seat the tapers?? J-29193??? or should i just crank down the nut???
Car: '89 IROC-Z
Engine: 355
alright ill check it tommorow thanks, its on and everything (didnt use tool do i need it??) along with some new front brakes going to grease all the fittings and align it tommorow at work.
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Apr 14, 2016 08:52 PM
LT1Formula
Nov 16, 2015 01:13 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
