vibration when rolling
Old Jun 4, 2008 | 09:24 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Ok so my car seems to shake a bit sometimes while driving. I started noticing it when accelerating. Doesn't do it all the time but just to try narrowing things down I coasted down a road in neutral and still had a bit of shake to it. I've noticed that the passenger side of the rear stabilizer bar has broken and it just hangs there. Could this be the cause, or something else?
Old Jun 4, 2008 | 11:35 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Re: vibration when rolling
Ok went for a long drive to get more data.. When slow accelerating, there is a shake which feels like it is right at the frame. Doesn't happen if I floor it. Most of the time it seems to roll without a problem but I do get a subtle shake at times.
Old Jun 9, 2008 | 12:10 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Are all four of your wheels balanced? This is what I would check first. did you put a new or spare tire on and not get it balanced? Or could one of the counter weights fallen off? Check your rims....
Old Jun 9, 2008 | 03:31 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Get your tires balanced and fix that stabilizerbar.
Old Jun 11, 2008 | 10:24 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Tires are balanced. Had it done recently when a pot hole killed one of my tires.
Kinda narrowing things down, but my problem may in fact not be suspension related. Hard to tell sometimes but it may actually be the engine shaking it due to a miss (which would explain it happening rolling in neutral)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
shanelique22
Oct 3, 2015 07:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
