a-arm bushing removal question
Old Jun 9, 2008 | 07:36 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Could the front a-arm bushings be removed without the use of a press? I want to get mine changed, but we don't have a press for me to use.
Old Jun 9, 2008 | 08:02 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Re: a-arm bushing removal question
You are going to need a press and some other tools to get those things out. When I did mine it was a PITA. Those things are in there pretty good.
Old Jun 9, 2008 | 08:08 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Crap. I was hoping I could do it tomorrow after work. Looks like I'll have to wait til I can get off early enough to get back to the shop and take the a-arms off and take em somewhere with a press.
Old Jun 9, 2008 | 08:43 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I used the "cup kit" (Ball joint press I think it was or something?) you rent at autozone and a hammer.
Old Jun 10, 2008 | 03:59 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Hmmmm.... I may have to try that. I could get it done much faster without having to find someone to run me across town to get em pressed out.
Old Jun 10, 2008 | 07:33 PM
oil pan 4's Avatar
Car: 89 Firebird
I drilled my rubber bushings out. Think I used a 5/16''s bit. Hit them with the drill a few times and then use a hammer and metal rod to finish them.
Never burn them out.
Try not to tear up the sleve to much, some times the poly bushing will slip right into them, but not allways.
If the sleves have to come out, a sawsall and a claw hammer works good.
Old Jun 12, 2008 | 01:43 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
you can always take the a-arm into a shop have them press out and install the new bushings.... less hassle
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 25, 2015 07:34 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
