Is it the steering box or steering column.
Old Jun 22, 2008 | 01:42 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
The Previous owner of my 92 Rs Had Previously had the bushings ,and basically all the rubbers replaced,the only thing he didnt replace was the steering box and steering column. Now the problem i'm having is that my steering is still loose. I believe that this is being caused by either the steering box or steering column. How Would I be able to tell whether it is one the other or both? Any advice would be appreciated
Thanks.
Old Jun 23, 2008 | 08:18 PM
Guest
Guest
Posts: n/a
Re: Is it the steering box or steering column.
The column itself would only have steering slop in the rag joint. A fairly inexpensive and simple replacement. Pull the shaft, drill out the rivets and instrall new rag joint with supplied screws to replace the rivets.
Then if that don't solve things..... its the steering box.
10:1 odds it is both.
Old Jun 23, 2008 | 10:10 PM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
I took a closer inspection and have come to the conclusion its the rag joint and the steering box both worn out. (155k) So I need to go to autozone and order some stuff up.
Old Jun 24, 2008 | 02:50 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
there is a write up on how to rebuild your steering box and replacing the rag joint,
https://www.thirdgen.org/forums/susp...build-rag.html
I was going to change my rag joint today, but it seems my play is in the box as well. I have almost 180K miles on my car.
Old Jun 24, 2008 | 07:00 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If the tilt is loose in the column it can add play to the steering.
I've not had good luck with reman boxes and gave up on them a few years back. I've rebuilt four or five boxes since then and always came out with a better box than any of the reman I've tried.
Old Jun 24, 2008 | 01:33 PM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Did you try adjusting the box first? They have a wear adjustment on top. The steering boxes on these cars are seriously over-built and almost never actually wear out, yet people replace them all the time anyway. The only reason to pull one out is if they leak.
Old Jun 24, 2008 | 02:58 PM
naf's Avatar
naf
The box should really be pulled in order to properly adjust it. The over center adjustment (on top) should be touched only after the input plug has been set properly.
Boxes don't really wear out but they are killed at times by the guy that cranks an 1/8th turn too much on that top adjustment nut without understanding what he's doing.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bubbaz28
Sep 18, 2015 02:09 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
