Little loose in the front end
Old Jun 22, 2008 | 01:47 PM
Samdweezel05's Avatar
I was looking at some of the steering parts under my GTA this morning looking for something that was causing a little slop in the steering wheel. Tie rod ends were good and tight. I did notice one ball joint, if that's what it's called, on the end of the steering arm comming off the steering box. Is this ball joint replaceable or do I need to replace the rod that connects both tierods to the steering arms. Maby there called pitman arms on these cars, I don't really know. It looks like the joint can be removed from the arm off the box but it looks pretty perment in the bar. Thank's
Phil
EDIT: I see now that it is called a relay rod and the ball joint I am talking about is the one that attaches it to the pitman arm off the steering box.
Old Jun 23, 2008 | 08:02 PM
Guest
Guest
Posts: n/a
Re: Little loose in the front end
Even if just one little pivot point has slop it will cause problems. You will need to bring the car up to perfect maitenance in the steering links before having it aligned.
Old Jun 23, 2008 | 08:20 PM
That's the plan. Hope to get it all fixed this weekend.
Phil
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
