suspension rebuild
Car: 1991 Camaro RS B4C
Engine: 5.7 350 TPI
suspension rebuild
so am new to the 3rd gen and planning on replacing my suspension right now
i have a 91 b4c camaro with 220k miles
the shocks look like its been replaced with cheap morono ones
so i bought a NOS set of KYB adjustable shocks and a used set of Pro line drop springs
what else i should look into replacing at the same time?
some bushings? the front shock mounts?
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: suspension rebuild
If you're going to do some of it, you might as well do it all, especially with over 200K miles.
strut mounts
tie rods (all 4)
ball joints
idler arm
sway bar bushings and end links
wheel bearings
If needed, the rotors, pads, brake lines, and either rebuild or replace the calipers.
strut mounts
tie rods (all 4)
ball joints
idler arm
wheel bearings
Engine: 5.7 350 TPI
forgot to mention
the steering and brakes were already replaced so am good on those parts
i was just wondering what suspension parts i should replace while am in there. i dont have money for go fast parts yet such as SFCs and LCA stuff...
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
A whole bushing kit for the whole car sin't that expensive. Just go ahead and replace all of the bushings at once.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
